Discuss Thumping manifold, bouncing flow meter in the Underfloor Heating Forum area at UKPlumbersForums.co.uk.
Thread Status:
  1. Wayne74
    Wayne74 New Member
    I have a Rehau underfloor heating system on the ground floor only of my house. Every so often, the manifold makes a knocking/thumping noise. When I look at the flow meters I can see the one that's making the noise and the little ball in the flow meter is bouncing up and down (so the water level is bouncing up and down, obviously). Could this be air in the system? It only does it when there is demand on that particular loop (the hall, so there's often demand as the temp changes due to the front door being opened). If I turn the pump speed down it simply changes the tempo of the thumping! Any ideas? The flow meters are beginning to look opaque so I guess the system needs cleaning out anyway, but the thumping has occurred on and off since the system was installed (now 5 years old).
  2. Daveplumb88
    Daveplumb88 New Member
    Sounds like (boom-boom) you need to replace the TRV head for that particular loop. I've had it happen briefly when the head gets to a certain position while closing down (they can take a minute or two), but not constantly. Have you also tried tweeking the flow limiter &/or the flow/return blending valve?
  3. Daveplumb88
    Oh, and I wouldn't worry too much about a bit of visible discolouration in the flow limiter glass. Though if you've rads upstairs, have you got a magnet/filter on the primary return?
  4. Sparkgap
    Sparkgap Active Member
    Just a thought: used to have occasional thumps on rad TRVs which were due to flow through valve being backwards! Have you checked the valve body to see if it's right way round for flow?
  5. Uheat – Wojtek
    Uheat – Wojtek Sponsor
    Hi Wayne,
    does it just happen to one flow meter?
    I've had a customer week ago with exactly the same symptoms at Uponor manifold.
    He replaced the flow meters and the noise is gone.
  6. Uheat – Wojtek
    Hi Wayne,
Loading...
Similar Threads - Thumping manifold bouncing Forum Date
UFH Conundrum - No flow through manifold. Please Help! Central Heating Forum Dec 28, 2017
Indentify heating manifolds Central Heating Forum Nov 29, 2017
Thread Status:
  1. ufh bouncing flow valve
