Discuss Toilet cistern farts after flushing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thank you for your reply. It has done it from new. So could it still be that? Thank you.Trapped air.
Possible partial blockage
Thanks Shaun- I'm not a plumber so do you mean where the water drains out from the cistern is the problem?Drains
The plumber who installed it said there's nothing wrong with it and that it's the shape of the cistern, but a plumber that my partner works with saw the video and said it's a faulty diaphragm.
I just thought I'd post on here to get another opinion and see if anyone has encountered it before and if it is just the shape of the cistern. Thanks for your help.
Hi Shaun, many thanks - here's the photo of the internals. Hope this is ok. CheersI'm doubting myself now any chance you could take a pic of the internals of the cistern?
Hi Shaun, just tried that - it still makes the soundCan you hold the float valve up (so it doesn't refill the cistern) and flush the toilet ?
Does it still make the sound ?
Ahhh. Interesting. It's to do with the middle thingy. I held up the wire part that made it flush and it didn't make the noise. It didn't refill either. As soon as I let the wire part go, it farted and then refilled. Does this help you? Cheers
Right ok so not a full problem I would say it's the flush valve
You could tomorrow clean the washer see if that helps
Grab about 2" up from the base of the flush valve and give it a turn clockwise should pop out and you want to make sure the rubber washer is clean and not damaged
the middle oneAs soon as you let what go the middle one or the right one ?
Hi Shaun, just saw this after I'd posted about the flush part. I'll have a look tomorrow when I'm more awake
the middle one
The metal wire on the left of the picture
Ps. I can't see any washer in that partThe metal wire on the left of the picture
Yes will do - thanks for your help. At least we've narrowed it down now to the area that's making the noise. Cheers.It's located where the water goes out when you flush the cistern
TBH it might be best to get the plumber back who installed the toilet
Hi, thank you - I did as you suggested and it made the noise as soon as the flush part has released all the water. It didn't do it at all in relation to the fill part (on the right).Screw the flush button back into the top of the flush valve, hold up the float on the fill valve (on the right) and press the flush button. Did it make the noise as the cistern emptied?
Now let go of the fill valve and let the cistern refill, did it make the noise this time?
Reply to Toilet cistern farts after flushing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
