Discuss Toilet fitting advice needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Thomas Barnes
hi all
Trying to fit a toilet myself. Got it all together except the plastic waste pipe coming out of the wall is too long by about 10/15cm. What do I do to ensure I fit the toilet up to it so I can fit it onto the wall?
Tom
Have trimmed about 5cm off the other end now the flange is flush with the wall and can't cut any more
Thanks!
No. I think it is glued on. Tried very hard. Should I just buy a new pipe?
The 110mm pipe needs cutting back 50mm off the wall buy a pan connector straight extention this is cutable to make up the length you require the toilet pan outlet compleate with the other pan connector pushes into this job done cheers kop
Ok brilliant. So just like this straight extension? Will this go directly
to the pan?
Ah hang on. The soil pipe I have won't go into the wall any further due to the cut out size. Best just get a fresh soil pipe and standard pan connector?
Reply to Toilet fitting advice needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
