Discuss Toilet leaking help in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. LisaM1983
    LisaM1983 New Member
    I'm a woman with zero knowledge on DIY and plumbing so I'm in desperate need of help!
    We have a really old toilet and it wouldn't flush so my father messed around in the cistern and it now flushes but water is leaking out of what I believe is the outlet pipe outside of the house and we're having to empty a bucket of water every day.
    Can anyone please give me any advice or am I best ringing a local plumber?
    Thanks,
    Lisa
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    The water level may be too high inside the cistern. Any chance of a picture of inside the cistern?
  3. LisaM1983
    I'm at work at the moment but I'll take one when I get home. Thanks!
    • Like Like x 1
  4. LisaM1983
    That's the leak!
  5. LisaM1983
    There you go, thanks
  6. LisaM1983
  7. ShaunCorbs
    Water lever too high or needs a new washer
    Flush the toilet
    Turn the bolt / screw in more
    One or two full turns should sort it out if not a new washer is needed
  8. LisaM1983
    Thanks. Sadly I can't shift the bolt and don't have any tools
  9. ShaunCorbs
    Sorry to say you only have one option get a pro in and replace the whole valve
  10. snowhead
    snowhead Well-Known Member
    The nylon bolt with the steel nut on it has a slot on the end.
    Get a wide ended knife (or a flat blade screwdriver would be better..)
    Flush the toilet so the float drops and takes the pressure off the screw.
    Then use the knife to twist the screw inwards so the nut gets closer to the black nylon arm.
  11. LisaM1983
    Thanks for your help anyway. Hopefully this isn't going to cost me too much!!! :eek:
  12. LisaM1983
    Thanks. Will try this
  13. Harvest Fields
    Cheers mate had no signal to respond;)
  14. LisaM1983
    Shame you're not local :(
  15. Harvest Fields
    Yep. Sorry. I am sure that there are plenty of good engineers up north.
    • Like Like x 1
Loading...
Similar Threads - Toilet leaking help Forum Date
Cannot find toilet seats with 270mm gap between hinges? Plumbing Forum Feb 11, 2018
Another toilet bodge Plumbing Forum Feb 3, 2018
