Discuss Towel radiator again, now I've registered in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Cockers
Hi, my towel radiator has just stopped working, the connections are all good. The timer program is working but when the timer kicks in to turn the heating element on , no blue light ,no electric sent to the element, it's called a time guard, FST-11A
if there no feed (elec) going to the element and theres feed going into the timer/ control then time for a new on
Reply to Towel radiator again, now I've registered in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My towel rail is not electric but separate to central heating and has been working consistently but since the 2 port valve was replaced on Monday because the radiators were not working it has stopped working, if I go into the loft and press the flame button on and off it seems to come back to...
Hi, I have an electric towel rail which has stopped working. All the lights are flashing from blue to red and the boost light is flashing green I have tried re-setting it but still no luck. Can anyone help please? I have the manual for it and it’s a Smart version from Advanced Heating Solutions.
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the normal radiators get hot but two of the three towel heater/radiators don't get hot and the pipes feeding them are cool to the touch even after the boiler...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6 other radiators and 2 bathroom towel radiators are just normal valve s. We live in a 4-bed, 3 storey house, as converted loft. Common problems were...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that has previously been extended. In one of the bedrooms that has been extended there are 2 radiators, one which looks like it was fitted when the...
