Discuss trickling/sloshing sound in pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dear all,
I'll start by saying that I know little about central heating systems so thanks in advance for your patience. I've just moved into a house that has the standard boiler system (not combi). There's a tank in the loft and a pump/hot water cylinder upstairs. Annoyingly, when the central heating turns on there's a trickling/sloshing sound in the pipes that leave the boiler. I assume that this is air? I do not hear this in the radiators though. My question is: is it likely to be air in the system? If so, what's the most straightforward way for me to get it out? I'd thought of bleeding the radiators but the air sound is only in the main boiler pipes. It is also much louder when the hot water is on as well as the central heating. Given that it's the holiday period, i don't want to have a go at anything that I can't easily reverse.
I would really appreciate some pointers.
Steve
Actually, the sound is really only when the hot water is on. The sloshing is not there when it's just the central heating......
Probably partial blockage of cold water feed encouraging small amount of air to enter system on startup,but also check you have water in the small tank in loft as ball valves sometimes jam closed. Slacken large central screw on pump, ( Do not drop and lose.) small amount of water should appear immediately. If air comes before water this confirms system is sucking air.
Having just read your 2nd post ignore the foregoing.
Thanks for the quick reply. Do you mean that I should just proceed with the pump screw only? If so, does the system and pump need to be on or off while I do it?
Steve
More than likely the cold feed and vent arrangements wrong, it'll also the water might be quite dirty. It's not really a diy job tbh.
Welcome to the forum's Steve.....you could check the "I'm looking for a plumber section" on here and you might find someone near you who can sort out your problem.....regards Turnpin:welcome:
Reply to trickling/sloshing sound in pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water comes on all seems ok then after about 15/20 mins i started to hear a trickling noise from hw cylinder which i can also hear in the boiler. The central...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to give a full picture but let me know if ive missed anything. I have a Baxi Avanta 25h heat only boiler. Works fine. Unvented 300ltr megaflow. Stated...
About 5 year ago, I had a new central heating system (radiators) installed to replace my old warm air underfloor system. The warm air side of the new system is okay but we cannot get any hot water without running a bucketfull of cold water first. This means having to wash your hands in cold...
