Discuss Turn hot water off from within Combi Boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just moved into a new flat and was just removing the old kitchen and cannot turn off the hot water to the property. I can turn off the cold but not the hot, looks like the boiler (Worcester 28i junior) is being fed from the loft that I cannot access. Can the water be turned off from inside the boiler to the hot taps? There is no other valves/taps to stop the water on the hot pipes.
Isn't there a valve on the cold into the boiler?
You should have access to the tank, if there is one.
If the tank serves multiple properties there should be a valve where the cold pipe enters the property.
If there are several flats there may be a tank at ground floor / basement level with a boost bump.
But there should still be a valve at entry point.
there will be a valve underneath screwdriver flat under the boiler 2nd pipe from the right hand side
So if I turn this clockwise it will turn the hot taps off?
yes normally best to get a decent set of pliers on the external flats saves damaging the slot
or just turn the water main off and fit a stop tap below the boiler on the cold
Thanks for this info, I would need to get into the loft to turn the feed off and this will probably turn the other 6 blocks off to. This was converted from a water tank I think.
hope you dont mind but i have a few questions
are you renting or have you bought the flat and are you planning on staying there long-term (5/10 years) ?
and you should know / have access to any stop taps in case of emergency
Bought and yes will be staying.
Depending on funding I would be looking to change the boiler as soon as funds allow it
To guarantee hassle free heating and hot water in the future
Think the boilers about 10 years old, is this a known problematic boiler? I did notice there is no condensate pipe going outside?
Be a bit older than that I think and yes it wasn't the best
Due to the efficiency it wasn't needed back then
Reply to Turn hot water off from within Combi Boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Combi boiler and, a few minutes ago I turned on the hot tap in the kitchen and the water was far from hot. In fact, it was decidedly lukewarm. I checked the boiler and the tap icon was lit up, showing it was delivering hot water to the taps and I could hear the boiler running and the...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a megaflo unvented indirect cylinder (125i) boiler is a Worcester greenstar. I have good pressure on the cold feed and all the usual stuff works, taps...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the upstairs taps, I have a combi boiler and no water storage
Mike Young
M
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in kitchen only Stopcock in kitchen wall panel turns off cold water supply in kitchen only Red gate valve in airing cupboard next to bathroom turns off...
