Discuss under sink water heater in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. apcdave
    apcdave Member
    hi chaps,
    have to fit one of these tomorrow - it's a 10 litre job. Instructions are as clear as mud/ however it does say " the connection to the hot water outlet is to be carried out with a cast iron or steel sleeve or dielectric connector " I have some 1/2 inch black iron fittings - can I use one of these with a brass female iron to connect to the 15mm copper ? which runs to the hot tap - many thanks dave
  2. ShaunCorbs
    Are you G3 registered??
    • Like Like x 1
  3. apcdave
    apcdave Member
    that would be affirmative ..course now you're gonna say why don't you know the answer to this
    • Funny Funny x 2
  4. ShaunCorbs
    Just use a standard 1/2 brass female iron
  5. apcdave
    apcdave Member
    thing is Shaun the MIs state " use of brass fittings on the hot water outlet is prohibited "..
  6. ShaunCorbs
    Do they supply two little plastic male to female adapters ?
  7. apcdave
    apcdave Member
    mmmmm.. I have not seen the heater yet, just the instructions; guess all will be revealed tomorrow
  8. ShaunCorbs
    What heater ?
  9. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Normally there is two white connectors in the box.
  10. Chalked
    Chalked Plumber GSR
    It's normally plastic female threaded adapters. These are to stop electrolytic action eating away at the glass lined steel vessel.
  11. apcdave
    apcdave Member
    thanks for replies chaps - it's an EAC ( ATL France )
  12. apcdave
    apcdave Member
    thanks guys - all sorted - 2 1/2 inch black plastic fittings supplied with the heater. I fitted 2 iron connectors directly to the heater then the plastic adaptors between these and standard 1/2 inch brass females
  13. ShaunCorbs
    Why did you use black iron fitting ????
  14. apcdave
    apcdave Member
    brass not allowed
  15. ShaunCorbs
    You can't use black iron on water mains, all that means is you need the transition fittings first
    So no going straight to brass off the heater
    So heater transition fitting brass :rolleyes:
Loading...
Similar Threads - under sink water Forum Date
Undersink/oversink hot water heater. Plumbing Forum Apr 4, 2018
Combination valve under kitchen sink?.. Plumbing Forum May 25, 2018
