Discuss Underground drainage leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
ground floor toilet was fitted without a stub stack, has its own drainage to the manhole. Owners want to sell so had to fit a stub stack for building control to pass it.
Fitted the stub stack, did a wet test and Water is slowly draining. I’ve checked all my joints and they’re dry.
Any way of finding the leak by any other means???
Dye but you need access to the joints
Is there anyway the toilet would be slow draining to fill the pipes and eventually stop? (I’m basically filling the run with flushing the toilet.
Only reason why it would be slow to draining is a blockage or maybe a split/ collapse
Here’s the thing..
I flushed the toilet until the pan filled to the brim. Filled the basin bossed into the run. Slowly drained. Did this 8 times and now ... completely steady, not draining at all!!
With your bung in ?
Did you air test it first and what's your drop ?
Building control ain’t interested in an air test, for them it’s either air or wet, and I don’t have the air kit
So it's staying steady / not draining over an hour ish ?
Correct. It’s been at the same level now for about 45 mins and I know it’s just a 2 min test so to me it’s all good?
Yep if it hasn't dropped after half an hour your golden
Ok.. so just been called back to custards reporting a huge leak (I left the run bunged and filled ready for inspection tomorrow as I wasn’t going to be there).
Turns out that when you flush the 1st/2nd floor toilets it causes the ground floor toilet to overflow. Now, this must mean the pipework is connected. But I was told it had its own run??? Also could explain why it drained and drained until it filled up properly.
Wtf????
Maybe they do have there own run but teed before the manhole
This is why air testing is better
That makes sense.
But to do an air test don’t you have to remove one of the toilets?
Sounds like it is teed into the same run otherwise no way it could go back up past a bung. To be honest I always air test soil, although mainly when new as opposed to existing.
I just use a test bung/bag in the toilet
Gonna find my air test kit I think. Not sure the bungs I have will fit in the pan, they’re metal with a rubber ring in between and you turn a butterfly screw to push the rubber out to fit the pipe
What do you blow this up with as they’ve got 1/2 inch females connections on the taps?
Mine do can't comment on the ones in the link
Reply to Underground drainage leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’m about to embark on a new listed building restoration project. There are seven bedrooms and three bathrooms, one of which in downstairs so not very convenient. I’ll be looking to sell on once completed and people basically expect a bathroom per bedroom these days 🙄 so need to get creative. As...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3 or 4 ribs on it). It's painted in a fetching pink/purple colour in the photo. Tried to revive it with some grease before inserting a short length of...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter put an isolation valve on the pipe work for this :-(, the copper pipe comes up from a plastic pipe push fit. See photo. I did a tissue paper test and...
1K
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the radiators but still gave hot water to the shower and taps. Naturally we thought there was a fault with the boiler. We had already arranged a yearly...
Hi all, Excuse the length but this seems like a complicated fix. I lived in a 1930s block of flats. Brick building with concrete slab floors. The waste stack is internal and bricked into corner of the bathroom. I noticed paint peeling and brown staining recently at the bottom near the...
2K
