Discuss Unknown radiator valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bmn
Good morning,
I have a radiator valve, but I am unable to find an equivalent online.
Unscrewed the internal cap from the left and I used it to put inhibitor in the central heating system, is that its purpose? Can you please identify it?
Thank you.
Thank you both, I was able to find it with "drain off". Sorry for the OT, but it's not an issue that I used it to put the inhibitor, is it?
Reply to Unknown radiator valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I want to swap a K1 radiator with a P+, the same size on a combi system. Can i turn off both valves, remove the existing radiator, put the new one on the existing brackets, and reconnect the existing valves, and then top up. Would draining the entire system be necessary? If draining is not...
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber is coming back in a day or so to make necessary repairs. I am a little concerned as the house has a Boilermate 2000 on the upper floor and the...
Hi, I'm looking to add some radiators into my property and ideally looking to match the style of the existing ones. I cannot seem to find anything online to match. I assume this style of radiator is no longer manufactured, but I might be able to pick one up second hand. Can anyone help me...
I have recently bought my own house and decided to redo the kitchen. There was a radiator in the room already but I wanted to move it. I extended the pipes (8mm microbore) and plumbed in the new radiator. I opened the isolation valves and filled up the radiator with no issues. I've bled every...
Hi Everyone, The metal spindal on the top of one of our radiator valves is snapped off and the radiator is always off, is there a quickish fix for this or will I have to drain the whole system to replace it, pictures inculded, thank you!!
1K
