Discuss Unknown Valve...Its a mystery! Expertise required! in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Kate0406
    Kate0406 New Member
    So my shower valve is apparently " letting by" cold water making all the water in my house luke warm. My plumbing friend has wedged it so that I can now get hot water everywhere (except in my shower). I need a new valve but it was installed 7 years ago and I have no record of where the shower was bought from. Attached are photos another plumber took to try and source the valve but has had no luck...can anyone help or will I have to replace the entire shower (and re-tile the whole wall) as I have been advised...photos attached. Help will be much appreciated x
  2. JCplumb
    JCplumb Plumber
    It's possible you could get that long stemmed valve (looks to be just a quarter turn valve like the ones in taps) from tap magician.
    Have you tried shower doc, if they can't identify it, you're probably not getting a part.
    Those guys do this day in day out and have years of experience identifying showers/valves. They're much better equipped to identify it than us.
    You might get lucky though, a fellow plumber on here may have experience of that particular shower.
  3. Kate0406
    Kate0406 New Member
    Thanks...I'll try both x
  4. rpm
    rpm Trusted Plumber
    • Like Like x 1
  5. deg
    deg Member
    A non return valve on the hot would save you a lot of base if you.can access the pipework somewhere
  6. Matchless.plumb
    Matchless.plumb Trusted Plumber
Loading...
Similar Threads - Unknown Valve mystery Forum Date
Heating/Hot Water Issue - Unknown problem! Central Heating Forum Dec 10, 2017
Gas fire shut off valve Gas Safe Register Forum - Public Forum Jan 6, 2018
