Discuss Unvented cylinder flow rate requirements? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys.
Just a quick question. I've been asked to fit a Worcester Greenstore unvented cylinder but I'm worried flow rate is insufficient. I measured the flow rate at 14 L/PM. It currently comes into the house in 20mm mdpe and goes straight to 15 mm after the stopcock to supply the house.
I would fitting new 22mm mains pipework to supply the cylinder. What effect would this have on the flow rate/pressure?
It's a whole house refurb so all new pipework and new boiler/cylinder. They currently have a traditional set up in place.
Cheers.
Ben
Take the flow reading from just after the stop tap but agree flow atm is too low
What's the pressure like ?
5 bar of pressure at the mains stopcock.
Flow rate varies between 12 & 14 l/pm
We currently have 20mm mdpe going into the stopcock and then straight into 15mm
I am planning on replacing the 15mm pipework with 22mm. Will this give me a better flow rate? And should I upgrade to 25mm mdpe?
Also would a cold water accumulator work to increase the flow rate?
Worcester say the min requirement is 1.5 bar with 56 l/pm flow rate.
Straight after the stop tap your getting 12-14lpm?
Phone the water board up and ask them what's the pressure and flow in the street / what should you get
Hi guys.
I've just read the Greenstore installation instruction and I've extracted the following:
In a domestic installation, 1.5bar working pressure and approximately 15/20 litres/min. should be regarded as the minimum. Consideration should be given to upgrading existing 1⁄2" (15mm) cold mains pipework to a larger size, if the recommended minimum working pressure/flow rate is not being achieved. Maximum pressure is 5.5bar. Therefore I would recommend increasing the internal pipe size (Stopcock to UVDHWC) to 22mm.
From reading the post it does appear as though you have very little experience of G3 installations so my advice would be to either take your time and read the MI completely, or get yourself on a refresher course for G3 - it'll only cost you around £150 for a day and you'll have the knowledge you need to feel confident with this kind of install.
Reply to Unvented cylinder flow rate requirements? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft but an unvented cylinder in the upstairs airing cupboard. A gas heat only boiler. Upstairs I have two en suite rooms. One with a shower and one with...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from the shower but it seemed no different from the original combi boiler hot feed. There is (unusually) a lever that lets me select the combi or the...
Steveo111
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the cause. I would like a flow rate of about 12L/min. Here is my set-up: Standard gas boiler (not a combi) in the kitchen, have cold water tanks in the...
Essaboy
E
Morning all, I have a Worcester Bosch 8000 life 40kw boiler on system with 7 radiators and the boiler is located in the loft of a 1907 end of terrace house. It has been range rated down to 50% and I currently have the flow temperature set to 64, due to slow warm up. I recently purchased a...
Simon from Watford
