I've been asked if I can install an unvented cylinder with the current baxi Bermuda back boiler unit, guy doesn't want to change the boiler as it is working fine and hears some bad stories with some new boilers which is fair enough.
Currently it is pumped heating and gravity hot water.
Am I correct in assuming I can cap the 28mm gravities off, repipe the pumped side of the bbu so I have a main flow to the cylinder, 2 motorised valves, auto by pass etc and a feed back to the heating system making it a fully pumped system?
Haven't had time to ring the manufacturer yet but any input would be appreciated
