M
masterkik
Unvented Indirect Slimline Vs Pre-Plumbed Unvented Indirect Cylinder !!!!
I need to put a mega flo type of Unvented Indirect cylinder in a kitchen larder unit, so need some advise on what options to consider as not too sure what would fit and would be a better solution. Hence have listed a few questions below:
1) How do i work out what size cylinder I need, as have two shower rooms and 1 bathroom with tub but never use it, and the house has 5 bedrooms and believe that 210L should be sufficient but need someone's advise on this
2) To fit the cylinder into a kitchen larder unit need to look for the slimmest option cylinder, as don't know how much space will the pipes take after the cylinder, as slimline cylinders are about 500mm in depth
3) Would a pre-plumbed cylinder be a better option instead of a slimeline and then worry about pipes taking up more space, but then cost of the cylinder goes up and not too sure how much would the plumber really save on pipes and time.
4) Which brand should I go for ?, and what should I look for when deciding as so many choices available which makes it more confusing.
Hope to hear back soon, thanks.
Regards
KK
Regards
KK
