Discuss Urgent help please. Water leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello.
Can anybody give me some advice please. My father wanted to get the old cylinder down from the loft so he has cut through a pipe at the bottom of the cylinder and there is water pouring out! They were told the cylinder had been drained, will it just be water still inside or could it be connected to something?
They have a combi boiler now so the cylinder isn't in use.
Managed to bung it with something for now but don't know how long it will last
Thank you
Are there any other pipes connected to it? If it's the one at the very bottom it's probably water that's left in the cylinder. Get a tray or two and collect the water. It could be several buckets of water
It's probably full
Any chance of a few pics ?
Reply to Urgent help please. Water leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all. This ‘valve’ is at the bottom of our domestic hot water cylinder. Anyone have any idea what it is please? It must’ve been there for many years and seems to be leaking.
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my 20-year-old unvented cylinder (an Ariston Classico HE STD 150) 5 days ago and I hadn't noticed that it was leaking. He fixed the leak today but now the...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have emptied the water tank in the loft and also closed the main stopcock. still the leak is on - hoping it will eventually stop. I have not idea how the...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the radiators but still gave hot water to the shower and taps. Naturally we thought there was a fault with the boiler. We had already arranged a yearly...
