Discuss Vaillant 430 Open Vented Boiler - Not firing up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Chaps,
We've just had a new boiler/system installed by a plumber and it was wired separately by a qualified electrician, the electrician wired this as per the Vaillant manual.
The system is fully filled and vented but when trying to call for heat or water via the stats nothing seems to happen. Live monitor shows S30 but not faults.
Any ideas what could be the issue? the plumber has been called to came and check it out again but he is currently on holiday and wont be back until next weekend, the customer needs the system working soon as.
Sounds more like you need the sparks back more than the plumber
Get the spark to check his wiring
S or y plan ?
Its an S plan system.
When calling for heat or water the pump kicks in but that's as far as it goes.
Will get the sparky to come back tomorrow. Any suggestions let me know so I get him to try....
Thanks!!!
yea quite simple hes wired it wrong pump on boiler should fire also pump might need wiring to the boiler
We've just had a new boiler/system installed by a plumber.....!
the customer needs the system working soon as....!
The plumber has shoved off and left boiler untested and un commissioned?
The electrician has shoved off and left boiler untested?
This has to be a diy installation gone wrong or a mate of yours
has fitted it and got out of his depth and now you need help.
All working now guys, wiring was double check and it was all correct, just needed to reset it by pressing the flame button...
Strange.... but it fires up now.
Thanks!
Is the benchmark filled in and boiler registered for warranty and Gas safe?
Reply to Vaillant 430 Open Vented Boiler - Not firing up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I was hoping to replace an old system boiler with a Vaillant Ecotec Exclusive 627 system boiler, thats the one with the diverter valve so no need for zone valves, controling it with a V-Smart and a VR10. I've spoken to Vaillant Tech and they said you cannot use the VR10 with a vented...
Looking for someone that can replace the expansion vessel on an old heating system that is losing pressure every day and needs topping up at least three times a day. Trying to eliminate what the cause could be. Appreciate that it could be a leak somewhere, but looking to tackle one issue at a...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended significantly since the boiler was installed. There's now 21 radiators/towel rails. It's getting to temperature, but even after balancing, it's not heating...
Hi all Wondering if you could help with this strange issue. I have a Vaillant ecotec 637 (set to 20kw part load) which was connected via a LLH to my system of 3 zones; DHW and 2 radiator zones. The gas usage was high and didn’t feel the boiler was modulating, so yesterday I decided to remove...
3K
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads in the house and a room with UFH. The LLH was introduced as I was finding (before the LLH was fitted) that my old boiler (Vaillant heat-only boiler)...
