Discuss Vaillant EcoTEC control panel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
On the front control panel, below the boiler rest button, is a small plastic cover with what appears to be a comms socket behind. This is missing on my friends boiler and they have been told not to use the it. Is this not just a cover or does it really affect the boiler.
Thanks in advance
Hi Scott, as it's not a tight fit, so not sure if it would be a seal if that makes sense. I'm sure it's just a small plastic cover, but as a result the boiler has been condemed and it seems the part is unavailable. It's only around 14 months old and it seems just too stupid for words to say it cannot be used due to a small bit of plastic missing off the control panel
Any chance of a pic ?
Hi
This is a pic of one that is on my boiler and is complete. It is the rectangular piece below the grey round reset button that is missing on thiers. Their boiler is near the same as mine. Hope this helps
Phone vaillant up they should be able to supply the part
This has been solved now.
As it was a council property there wasn't a lot we could do. However, the gas engineer went to another council property, that has had the same boiler installed last week, and took the plastic cover off of that one. Boiler no longer condemned
If the plastic cover can be removed without the use of tools then it can't be a safety critical item.
However as it's a Landlord's Property then they may have their own rules about what can and can't be left exposed for a Tennant
Did he then condemn the one he took the plastic cover off :D
Reply to Vaillant EcoTEC control panel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
