Discuss Vaillant ecoTEC plus 837 R1 with persisting F75 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can someone help diagnose Vaillant ecoTEC plus 837 with persisting F75 fault please?
We already replaced the pressure sensor, installed F75 kit, replaced the main heat exchanger, and the pump, and the PCB, and flushed the system and installed a filter on the return, but still sometimes we get F75. The boiler still reset and run, but we would like to get to the bottom of it if at all possible. Thanks in advance.
All those parts has been replaced in the course of 5 years not all at ones, and from different reasons, but the F75 has been creeping out all this time, some times the fault would be gone for months so you think that it was cured. The boiler is otherwise working well. There are two questions: 1) if there is a fault why the boiler always reset and continue to work sometimes for months? 2) if there isn't a fault why is the F75 keep creeping out? Thanks for your thoughts.
Yes, every three months or so, and it does seem to keep F75 away for a while, we are now on 1.8 bar when cold and 2.1 bar when hot
I believe F75 is a fault code for when boiler pressure is too low/ also doesn’t detect an increase in pressure when pump kicks on. Have you ever noticed what pressure your boiler is sitting at when this code is showing?
I noticed that if the F75 starts kicking and if after the first reset F75 returns, it makes it calm down if I top up. Last time boiler was at 1.7 bar before the first F75 kicked in. Generally speaking Vaillant have different fault code for low pressure and the boiler can work very well with 1.2 bar or even a bit lower, but that only if the boiler is not faulty.
ah Right could be a number of things. Sound like a defect in the sensor or it’s partially blocked if it needs such a high pressure to pick up anything. Has your expansion vessel ever been investigated as well as everything else you had mentioned?
I will check the vessel. After installing F75 kit is it best to leave the bottom sensor connected or it's best to disconnect it's plug?
Best to get a gas safe engy
I thought that this forum is there to help one another, so sorry for troubling you.
You are gas safe or your getting one ?
We have found the solution. For those of you who tried to help, if you would like to know please pm me. And to the others that didn't, no, we are not DIY
Do you have an external pump as well as the one in the Boiler?
Why would someone as a professional gas safe engineer make the customer poor by changing almost the whole boiler? Why not calling manufacturer and get some information or perhaps get it solved via warranty. It doesn’t seem very good to change all those parts ... very unprofessional
Why would someone as a professional gas safe engineer make the customer poor by changing almost the whole boiler? Why not calling manufacturer and get some information or perhaps get it solved via warranty. It doesn’t seem very good to change all those parts . very unprofessional
Apparently changing bits here and there over 5yrs cured it only for it to return after a few months is the answer.
Reply to Vaillant ecoTEC plus 837 R1 with persisting F75 fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also have an UFH zone in the kitchen. Near the boiler I have 2 port valves which control this part of the system. The boiler has been loosing pressure...
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads in the house and a room with UFH. The LLH was introduced as I was finding (before the LLH was fitted) that my old boiler (Vaillant heat-only boiler)...
Hi I'm dealing with Vaillant Ecotec 824 R1 in one flat. The boiler make a very loud noise when central heating is on - this is random and occurs mostly at night. I'm sharing video showing the problem: So far we changed: 1. Expansion vessel 2. Pump 3. Water pressure gauge - analogue sensor...
Hi everyone, I'm hoping to get some advice on an issue I'm having with my Vaillant Ecotec Pro 24 boiler (R1 PCB). It was installed in 2013 and has worked perfectly up until this week. When the boiler does start, it runs for a few seconds, makes some noises, and then shuts down again. I've...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
