Sedgy40
Didn't have boiler manual
fault code is S97
Water sensor ?
Hot water is warm and not hot
Heating is ok
fault code is S97
Water sensor ?
Heating is ok
Discuss Vaillant ecotec plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Need to get on with vaillant then and there boiler course. Might help usS code on Vaillant is a status code, that one is normally pressure sensor test running and it might cause restricted performance. If you depressurise the Boiler, the gauge pressure should read zero, if it doesn't then the pressure sensor will most likely need replacing. They slowly become blocked with magnetite.
Could this fault also affect the bar pressure as the warning pipe was passing slightly
Reply to Vaillant ecotec plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
