Discuss Vaillant / GW accreditation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks,
Struggling to get an answer from Vaillant on this, I can never get through... what's the minimum number of installations to get/keep your accreditation?
Best
PP
Reply to Vaillant / GW accreditation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I currently have an ideal mexico 2 heat only boiler - It has one DAB pump on the boiler return and a 2 port valve at the flow pipe to allow for heating...
I am considering replacing my existing boiler with the new 2023 Vaillant ecotec plus 625 boiler. I currently have 3 x Heatmiser neoStat thermostats that are all hard wired back to the wiring centre; one for the central heating, one for a room with UFH, and one for the HW. I use the Heatmiser...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended significantly since the boiler was installed. There's now 21 radiators/towel rails. It's getting to temperature, but even after balancing, it's not heating...
Hi, I was hoping to replace an old system boiler with a Vaillant Ecotec Exclusive 627 system boiler, thats the one with the diverter valve so no need for zone valves, controling it with a V-Smart and a VR10. I've spoken to Vaillant Tech and they said you cannot use the VR10 with a vented...
C
I got my regular annual boiler service for my Vaillant ecoTek 930 about a month ago, and the engineer identified that the AAV was leaking, so he closed it. This is a tenanted property and it's not straightforward to get access to it. How risky is it to / how long can I leave the AAV closed...
Cabe F
C
