PlumbBobBob
it is all getting very monotonous now imho
Discuss Variable flow Water Pump for instant water heater? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
la diddly la la (change of tempo to improve the thread )
So professional advise is get a system that last 10min and take 3hours to recharge.
Well...
I already get the flow I need, what you mean by "only attainable by a boiler or a stored water heater"?
I am not try to get an advise about "how to fix it", I am try to improve it.
The instant heater normally place within 2M from the shower head, as I place it in boiler room the hot water pump can restore the pressure lost when the water pass through the pipe.
The pulsa coil boiler do have an internal hot water pump to increase the pressure too, I cant see the why install a hot water pump will cause problem for the instant heater.
Since the pump can tune the output, I can get the increase pressure at the level I need without temp drop too much.
If you say no to the set up, please give a physical reason to it. Otherwise that will become the fight of religion again.
Reply to Variable flow Water Pump for instant water heater? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
