Discuss Vent pipe leak?? Lead flashing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When you get access to the roof, dry off the pipe and slate if wet, and seal up with a good quality sanitary silicone or a gungy roofing mastic and add a weathering collar as Shaun advises.I can see the gaps around the pipe from inside the loft. Although they’re not very big.
Reply to Vent pipe leak?? Lead flashing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
