That's fine I welcome your questions to hopefully get to the bottom of this. I had the stoptap off for about 3 hours and there was no movement. When the water company guy came he said if there was a leak he could have seen even the tiniest drip showing on the meter.
To be honest I thought the same at one point as I have a neighbour from he'll who also has the know how to do such a thing due to his job!
Tests suggested so far haven't discovered anything so I think I will have to get someone in to investigate further. I appreciate all the help and suggestions received.
Ignoring fora moment the CWS issue - If the neighbour IS using your water,it would only show movement when he is using the water. Say for an outside tap or equipment in garage.
What does CWS supply? Have you a (maybe tank fed) dishwasher and/or washing machine? Could the inlet valves on one of these be passing?
