Discuss VERY strange leak - advice appreciated! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SarahF
Hi everyone.
Today I noticed it was wet under my kitchen sink cupboard - after various trials trying to figure out where the water was coming from I found it was coming from the black drain part that connects to the sink and what the plughole drains down into (it will have a name I'm just not sure of it and don't want to quote inaccurately)
Now for the weird bit. Mine only leaks when I run hot/warm water down it. If I run the cold tap for over a minute there are no drips. If I fill a washing up bowl with just cold water and pour down with some pressure, there are no drips.
If I run the hot water tap however, even if it isn't hot (it takes a minute or so for the hot water to flow through) the drips start immediately.
I wondered if it was somehow the hot tap leaking so boiled the kettle. Soon as I started to pour the drips started.
Wiped everything dry, tried again with cold for a full minute. Ran my finger along; still dry.
Turned the hot water on (even though it was barely lukewarm); drips from turning the tap on.
I'm sorry if I sound ignorant but I thought if something was leaking it was leaking, and if it wasn't it wasn't. Does anyone know what may be the issue?
Is it a mixer tap you have ?
does it have one control , or two separate ones ?
( I'm thinking tap is to blame)
-- Fill up a washing up bowl, other vessel -wait/dry up -then do test
Hi
Thank you for replying - yes it is a mixer tap.
I did do the washing up bowl thing a few times earlier, in fact I've run so much hot water today my immersion has run out for the first time ever.
Washing up bowl full of cold water (cold water tap run only) - no drips
Dried everything
Washing up bowl full of hot (later only warm) water - drips (but no drips when bowl filling i.e. tap was running into bowl rather than straight down plughole)
Dried everything
Cold water running directly down plughole - no drips
Hot/warm water running directly down plughole - drips.
I then dried everything again and tested water heated by the kettle, no taps running at all - drips.
The leak only happens when something goes down the plughole at a warmish temperature; when I run the hot tap into the washing up bowl the area is still dry.
The only thing I can see dripping is the part that attaches under the plughole that the ubend then attaches to.
When you look down the plughole can you see a screw in the middle?
Hi
Yes there is a screw.
I did think it may be my tap but like I say even kettle boiled water caused a drip, even though no taps were on at that time. Dried it off and cold water run seconds later caused no drip.
Just ran some leftover pop down the sink; no drip. Ran some cold after to clear it; no drip.
It's just warm/hot water for some reason.
Hi
I turned the screw but no difference I'm afraid.
Drips when hot tap used but doesn't drip from the cold.
Also drips when hot water from the kettle is poured down with both taps off.
I have posted a picture of where the drips are coming from.
Look for cracks in grey pipe , getting things nice and clean can make leaks worst !
( Dismantling / cleaning / reassembling --will give an understanding -buts its MESSY )
May also need some spare parts if its all gone wrong !
I think the grey pipe is the dishwasher drain? The dishwasher has never been used since I moved in and the pipe is dry. The drips are coming from the black part to the left and above the pipe it seems
Simple expansion and contraction issue. Hot water caused the metal and plastic to expand at a different rate making a gap between them which is tighter when cold. Solution is to remove the waste from the basin unit, clean and reinstall using a new gasket and sealant. Better still fit a new waste.
had the same problem at home recently waste from sink would only leak now and then
my sink waste is white cleaned all around it and it looked like a hair on the pipe
in fact it was a small crack when hot water went down waste the crack expanded making the leak when cold water went down sink pipe was contracted no leak
I put some plumbers sealant on the crack had no problem since-good luck
You have a combined kitchen sink waste and overflow cheap to replace you can tell its leaking where it connects through the sink , you could try a repair clean it and add some silicone sealant but if you do then you may as well change it cheers kop
Reply to VERY strange leak - advice appreciated! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then drip slowly after that...........i put a bucket under the shower head to collect the water for 26 hours the first time.............then 19 hours the...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of copper pipe between compression fittings on the hot water feed. There are take offs for an outside hot and cold tap together with isolation valves and...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my 20-year-old unvented cylinder (an Ariston Classico HE STD 150) 5 days ago and I hadn't noticed that it was leaking. He fixed the leak today but now the...
