Currently reading:
Vokera compact 28 hot water isn't fluctuating cold and hot
Discuss Vokera compact 28 hot water isn't fluctuating cold and hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
went to see about a problem. I've never dealt with these kind of boilers. I'm new to it so be gentle..
Any advice what the issue could be? Blocked flow ?
Hot water is fluctuating ???
If so check the temps at the plat heating side if there not moving much I would be looking at plate
Unless the boiler isn't staying fired then could be flow switch
does the boiler flash on and off?
sounds like it cant get the heat away
heating ok?
could be a few things but i think dirty plate or system (hex)
if its doing the same in heating then its the hex
Also I went to that other job today. It was one 40 cdi Worcester heat only boiler 35mm gas pipe.
Max ratio 0.0007 min ration 0.0001
Ppm less than 100.
I did a gas rate imperial meter timed for one relvoution of a turn.i used my phone app.
check pump and water quality also main hex
Ok but when your working for estate agent you not have long to view the job to then put an quote in to get the job, so you think it could be the pump or main heat exchanger?
your the gas engy tell them you want more time
Reply to Vokera compact 28 hot water isn't fluctuating cold and hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
