Discuss Vokera Mynute 20 VHE. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 32524
Hello,
Thanks for looking. Been to see above and it is needs heat exchanger cleaned out. been told that I need to take a 0.4mm tool from vokera or a feeler tool to clean. Where is this tiny gap that needs cleaned? Any tips on the best way to clean it, thanks.
Thank you,
Duncan.
It is making a trombone type noise at min, also puts air down the condensate, so defo a blockage on the hex in terms of air flow. I have prepared myself for taking the whole thing out with new seals and washers, also going to change probes when its all out. Was thinking of using a bi carbonite of soda and water mix to aid cleaning.
What type of hex is it ?
Standard round one like in the ideal vogue and Viessmann etc ?
Also vinegar is better
Whole thing was over complicated in its explanation. Stripped it down, took it out of the drum, cleaned it, replaced seals and probes, runs sweet now.
Reply to Vokera Mynute 20 VHE. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
