Discuss Wachine Machine vs Sink problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Grey flexible tubing on the left is the washer/dryer waste.
We've noticed waste from the sink has ended up in washer/dryer.
Also whilst it's running now I hear a noisy squelch coming out of the sink drain, like it's sucking in.
It's a new washer/dryer, can't remember if it happened with the last - I meant to check the position of the drainage pipe so that it's high at the back, but it's been running.
I'd appreciate advice, thanks!
The pipe the washer should loop into the waste move the inlet upwards , its no good horizontal
You may want to add a jubilee clip whilst your there.
Reply to Wachine Machine vs Sink problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
