Discuss Wall type? Advice needed please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
Hi all. Ive been helping my brother in his newly aquired house and the internal walls are breeze block. Not the notmal type I’ve seen before but they seem to have hay in them? Also they’re not solid all the way through. I’ll add a picture as its easier. My question is whether its safe for them to be chased?
L
Seen similiar as internal walls the straw was for insulation these were the original partition walls as far as I remember the load bearing walls were solid 6" blocks and they were the internal walls last time I seen them the house was from the thirty's we chased them and used sand /cement to fill the chase then and slabbed over and plastered as long as your not knocking the crap out of them you should be okay
Just thank God they're not Stremic walls. Compressed straw faced with plasterboard. You couldn't make it up!
And they huffed and they puffed and it all turned to mush cos someone dribbled on it... Sh1te. :confused:
My house is made of those
Reply to Wall type? Advice needed please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my plumber is coming this week to install/reconfigure the pipework for new radiators. The walls are solid brick and as I am installing insulated plasterboards, we agreed...
3K
Hello, I'm a homeowner, not a DIYer. I have an almost 1 year old SaniCompact Comfort wall-hung toilet which has worked flawlessly until about a month ago. The last couple of times it was used, it made a loud noise and acted like it didn't want to flush. I guessed that it might be time to...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled toilet with a more affordable model. This new toilet is a back-to-wall type featuring a concealed cistern within a separate unit. Since its installation...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to create a cloakroom toilet in our utility room, theres already hot and cold feed so thats one job made slightly easier, thankfully. The problem I'm...
Hi all, My partner and I recently bought a house and have been attempting to make the bathroom less fugly. I was removing the bath and shower taps to replace, but while removing the bath spout (which had no nut to undo), the threaded section of the pipe broke. I thought the bit that broke must...
