Discuss Waste size slightly smaller than inch and 1/4 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
mikeyc
Went to an emergency call out today at a hair salon that has a load of foreign basins and traps are all leaking. I need to change them out but my problem is that the waste shank is slightly smaller than inch and 1/4 - like almost fits.
Anyone know any other sizes it could possibly be or suggest where to start looking.
Cheers in advance for any pointers
35mm?
1 1/4 push fit ?
No I mean the actual threaded shank on the bottom of the waste is smaller than 32mm so a 32mm trap is too big to screw on. Can't change the wastes as these are a god awful shape, size and design
Solvent 1 1/4" is 36mm, push fit is 35mm and Euro size is 32mm.
If it is Euro you will need an adapter like a mcalpine S28
As tamz said if it was me i'd swap the wastes out in the sink to standard uk size
had quite a number of sink wastes that normal traps wont sit on correctly recently, blumin euro carp.
Reply to Waste size slightly smaller than inch and 1/4 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm trying to connect 3/4" copper to 22mm copper in an old house. However it appears that the 3/4" is actually slightly smaller (measured at 21.1mm) than it normally is. This means I've been unable to use the special 3/4 to 22mm compression fittings as the olive is just too loose...
Hi guys question about saniflos đź’© I'm working at a property that the entire place was fed off a sani, that's packed up, blocked the line entirely and they've urgently had to get me to replace and make some changes, initially I was going to install a sanivite for the kitchen sink separately...
Hello there! I hope your weekend has started well. TL/DR: Should I replace 90-degree bend with a smaller type to increase the fall from the shower tray? I am replacing a bathtub with a 1500 X 800 Sonas shower tray which I will place on 4-inch blocks, probably with some 18mm marine ply on top...
2K
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution I could see. I'm in Brisbane, Australia but I'm after general ideas from anyone here or in UK (I realise this is a UK based site). Point form...
C
Hi I have a sink that has the basin plus another smaller basin next to it, think it is a 1/4 of the size of the main basin. The unit comes up through one hole, has 2 taps that turn and the unit can swivel to go to either basin. The taps have 4 prongs that can be turned (sorry not technical)...
