Discuss Waste water pipe fitting options in the Plumbing Jobs | The Job-board area at PlumbersForums.net
im redoing the kitchen and want to relocate the position of pipe that goes to the waste water outlet.
currently the pipe came straight up from the floor into an under sink unit like this....
This current arrangement sits too high which means id have to re route it through adjacent units in order to reposition it.
The sink is being removed permanently so this drain will only serve the washing machine waste.
if possible it like the pipe to run below the plinth before coming up in/near to the washing machine new location which will be a couple of metres away.
Is there any sort of low profile fitting and elbow arrangement that i can get that will allow me to run the pipe work under the new units rather than having to have the pipe work running through adjacent units?
somthing like this should do
McAlpine Drain Connector 110mm
you might need a short bit of 110mm depending on whats in the floor (just enough for the socket)
Reply to Waste water pipe fitting options in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine waste but the problem is in the water supply. Currently there is only hot and cold washing machine hose fitting isolators attached to very short...
R
Do I arrange new pipework to be fitted (downpipes and sink and washing machine waste pipes) before or after new render is applied?
Hi, We have noticed for a while now that when our washing machine nears the end of a cycle we get a bad smell of dirty water in the downstairs toilet which is next door. We have moved the washing machine as we are having floor tiles put down and have noticed that the waste pipe is full of dark...
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with the experience I have picked up over a lifetime. I can make copper pipe runs isolaters taps sink shower etc but me and the missus have bought a small...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of copper pipe between compression fittings on the hot water feed. There are take offs for an outside hot and cold tap together with isolation valves and...
