1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Dismiss Notice
Couple of important things to note. 1. We use Cookies, deal with it. Every website does. 2. Nobody but a currently-registered Gas Engineer should be touching gas or gas appliances. Don't mess with gas at all.
Discuss Water behind tiles in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. kasser
    kasser Member
    If the plasterboard has been properly tanked then tiled over in the bath area and water ends up behind the tiles, wouldn't the water just drip down to the floor where it will rot the wood?
    Tanking the plasterboard doesn't stop that...
  2. Chalked
    Chalked Plumber GSR
    Yes you are correct. You shouldn't have leaks behind. The tanking is to stop sower water penetrating to a substrate that is not water resistant.
    Struggling to make out if your post is a statement, or question. .?
  3. kasser
    kasser Member
    No, it's a question:
    Water goes through grout behind tiles and get stopped by tanked plasterboard. It then drips to the floor. So how do I stop water from ending up on the floor behind the bathtub?
  4. Chalked
    Chalked Plumber GSR
    Grout properly and silicone any movement joints, corners, round shower fittings and the bath edge.
    • Like Like x 1
Loading...
