  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss water not mixing through shower attachment in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. smudgie56
    smudgie56 New Member
    I have just installed a bath mixer tap with a shower attachment. The hot water is gravity fed. The water can be mixed to a suitable temperature through the tap, but when the diverter valve is operated, the water either comes out hot or cold. Any advise would be greatly appreciated. Thanks
  2. Matchless.plumb
    Matchless.plumb Trusted Plumber Top Contributor!!
    Hi smudgie,
    What bath mixer and diverted have you got ? Do you have any pictures ?
    Regards
    Ron
  3. Christopher buzzard
    Christopher buzzard New Member
    Is the cold water off the mains? With the hot being gravity and if the cold is mains fed then you have a difference in pressure. The cold will over ride the hot because of the higher pressure.
    • Agree Agree x 2
  4. king of pipes
    king of pipes Trusted Plumber GSR Top Contributor!!
    Hot and cold suppplies of different pressures dont mix and work very well on a manual bath shower mixer tap , two option reduce the pressure on the cold inlet to the bath shower mixer or pump your hot supply both will need a plumber to sort out cheers kop
Loading...
Similar Threads - water mixing through Forum Date
Thermostatic Mixing Valve 22mm for hot water cylinder outlet? Valves & Taps Aug 4, 2017
Thermostatic mixing valve on an electric instantaneous water heater Valves & Taps Oct 3, 2016
overflow from cold water tank in loft Plumbing Forum Today at 10:35 AM
New water main insulation Plumbing Forum Today at 9:53 AM
hot water cylinder question, can one of you great people help. Plumbing Forum Yesterday at 10:12 AM
Connecting mains cold water to gravity cold water. Plumbing Forum Friday at 6:49 AM
water usage Bathrooms, Showers and Wetrooms Wednesday at 2:42 PM
