Discuss Water regs regarding drinks water fountains in schools? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'l be starting a job in a school soon where im installing new drinks water fountains. Does anyone know if there are any specific requirements where i am able to tee into the water mains. I know there are supposed to be periodic checks to check the quality of the water at the outlets, anyone know how often and this process?
Best course is to phone your local water board
Reply to Water regs regarding drinks water fountains in schools? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals. We've been in our house for over 3 years now, when we moved in the hot water pressure was pretty good (confirmed by a retired plumber family friend)...
For residential housing, what are the current regulations and/or recommended/standard practices regarding the supply of cold water to the taps on kitchen sinks and bathroom washbasins? Must the supply come directly from the mains or can it come from the cold water storage tank? Or is the...
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor flat above it, and both share the same mains water pipe, and I believe the stopcock behind the washing machine isolates all water to both properties...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
I have a seemingly impossible problem. I am not a plumber but I can at least understand some of it. We have just had the Water Board inspector here and even he went away flummoxed. OK ....we have a stopcock under the sink that is stuck open - no amount of force will turn it. We need to turn...
