Discuss Water supply to outhouse in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Did you just use the normal grey pipe lagging to insulate the 15mm pipe?I came off my outside tap and installed the 15mm plastic inside a 42mm waste with the 15 mm insulated in the 42 mm and had no problems
The thicker one it just fitted into the 42mm but it is also in quite a sheltered part of the property.
in that case connect near your outside tap and run extension underground in blue poly,Can I bury the pipes as it would be a shorter route to cut across a pathway at the side of the house rather than going all the way around the walls?
Does it have to be the 20mm mdpe or can I use 15mm or 22mm plastic like hep or polyplumb?in that case connect near your outside tap and run extension underground in blue poly,
Use the blue its stronger and made for underground use only thing is the size of coil think smallest is 25 mts but cheep.Does it have to be the 20mm mdpe or can I use 15mm or 22mm plastic like hep or polyplumb?
Yeah ok I will do, thanks again for your helpUse the blue its stronger and made for underground use only thing is the size of coil think smallest is 25 mts but cheep.
Ive put a bottle gully in just outside of the outhouse connected to the main drain running to the manholeDare I play devils advocate and ask where the waste of the washing machine is running to
Thanks very much, cant wait to tell the wife lolLovely. Great work.
Could I possibly insulate this with a good pipe lagging so I dont have to dig so deep?In That case I would be using 20mm MDPE blue pipe, it is less than ÂŁ30 for a 25m coil. And no less than 750mm below ground level to avoid freezing!
Whats your view on the water supply pipe being insulated and buried, can I get away with not digging 750mm if I put a decent lagging round the blue mdpe?No before the pipe was laid lol .
But honestly is ok , most builders I know would nt bother
Reply to Water supply to outhouse in the Plumbing Jobs | The Job-board area at PlumbersForums.net
