Discuss Water Tank Corrosion in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Gosportdave
Hi
Can anyone advise how to remove the corrosion on the temperature and relief valve on the outside of my tank.
There is a very slight drip occasionally but not much.
I have attached a photo.
A dripping T & P valves indicates a potential problem. This is an essential safety device that should be looked at by a G3 certified plumber. Cleaning it will possibly make any leak worse. It needs testing, reinstalling or replacing if necessary.
Time for a service call get your G3 egineer to swap that dont mess about with it as you could make the problem worse cheers kop
Reply to Water Tank Corrosion in the Plumbing Jobs | The Job-board area at PlumbersForums.net
