Discuss Way to work out flow rates in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. southcoastboile
    southcoastboile Plumber GSR
    does anyone have a chart or know an equation to work out how pressure will improve over the length of the pipe.
    We have installed an unvented cylinder in a loft and have 14lpm with water softner connected. 18lpm without. 2.2bar pressure at shower upstairs.
    Customer wants more pressure as they have 25lpm at tap downstairs. 4.5bar pressure. Confirmed by water board apparently.
    The main runs up to the cupboard in 15mm so we are looking to find out what the lpm gain would be if we were to upgrade the 15mm pipe to 22mm.
    I wondered if anyone had a sum to work it out. I.e every mtre in height of 22mm pipe will reduce the flow rate from at the tap by 0.5lpm or something like that?
    Many thanks in advance!
  2. ShaunCorbs
    Can the water softener do 25lpm ??
  3. southcoastboile
    I'm not to sure to be honest.
    I will see if I can find out the make and model of the water softner and see what max flow rate it can achieve but it would be useful to be able to go back to the customer and say, in theory, if water softner can cope or it was bypassed, We can upgrade the 15mm pipe and the lpm will improve by such and such.
    I've looked online for a way to work it out but I can't find anything simple?
  4. ShaunCorbs
    If the incoming is 25lpm
    How many elbows and pulled bends
    Is the feed direct eg just for the cylinder
    Distance
    Etc ??
  5. southcoastboile
    Incoming is 25lpm.
    I think about 6 elbows in total. Mains feeding unvented cylinder only. Currently in 15mm.
    Unvented cylinder is in the loft at the moment of a normal sized house.
  6. rpm
    rpm Trusted Plumber Top Contributor!!
    When you say pressure is that static or dynamic? Was at a house recently where static was 6bar & dynamic was 0.6bar.
    • Like Like x 1
  7. ShaunCorbs
    22mm will be more than good enough
    Try and do as many pulled bends as pos tho
  8. southcoastboile
    25lpm and 4.4bar I believe this is static and dynamic pressure?
    Customer wants to know what gain they will get by upgrading the pipe that's the problem. I need a formula if there I one to give a rough idea as to what the gain may be.
  9. steadyon
    steadyon Active Member
    1. Have a look at http://copperalliance.org.uk/docs/l...eating-systems-pdf.pdf?Status=Master&sfvrsn=0
    2. Measure the customers incoming flow rate and pressure for yourself - if the water board have measured it, it may not be at the property but at the meter.
    3. You could always disconnect the output side of the softener and measure the maximum (open pipe) water flow, but you'd need to be sure there were no restrictions on the input side.
    4. With respect to your post #3, You might want to suggest to the client that "altering xxxx to yyyy might in theory result in zzzz". I'd be very careful about making any direct promises
    • Agree Agree x 1
  10. rpm
    Dynamic is always lower than static pressure.
  11. scott_d
    scott_d Plumber GSR
    Have you done your own tests or just going on the information from customer/waterboard?
  12. Last Plumber
    Last Plumber Plumber GSR
    You need to look further into that. There's too big a difference.
    If you are measuring 4.5 downstairs in a 'normal house' I would be expecting 4.0 in the loft, or there and there about's. How can it have lost 2.3 bar ?
    How did you measure the upstairs pressure?
  13. Last Plumber
    Just read the original post again.
    If you are measuring the Shower water pressure, (presume this is off the new cylinder)? You are measuring it after the Governor/Regulator.
    If you increase the pipe size from 15 - 22 you will reduce the frictional losses. To calculate the amount you need to know route, distance, how many bends/elbows etc.
    To measure the pressure loss through the supply to the cylinder you would need to know the Dynamic Pressure before the water governor on the cylinder and the same at the stop tap at the same flow rate.
    I don't know if this helps?
  14. Ric2013
    Ric2013 Plumber
    No. That's flow and pressure. At a guess, I'd say the 4.4Bar is the static pressure.
    • Agree Agree x 1
  15. southcoastboile
    Thanks rik. That's what I meant sorry. Just like standing and working pressure at a meter.
    Thanks for reply last plumber. So let's say we know the dynamic pressure at the stopcock and before the pressure reducing valve. What calculation would you then use to work out what you would potentially gain by upgrading the pipe?
    Its okay knowing pressures prior to the cylinder pressure red valve and at the stopcock but they won't be the same due to the height the water is traveling and the restrictions in the pipe work. I.e bends and sockets.
    I would assume that pressure at stopcock and flow rate would be all that was needed to work out what pressure you would achieve the other end of the pipe.
    For example 25lpm and 4 bar at stopcock would reduce pressure by 0.2lpm for every mtre of horizontal pipe. 0.4 every meter of vertical. 0.2 for every bend, 0.1 for every socket.
    Surely someone must have come up with a simple equation like that?
Loading...
Similar Threads - flow rates Forum Date
Hot flow and return pipes, hot upstairs rad but cold rads downstairs Central Heating Forum Thursday at 9:38 PM
Header overflow - should be so simple. Plumbing Forum Sep 7, 2018
