Discuss WC branch pan connector in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi.
I've got a situation where there is a soil pipe passing through a bathroom and turning 90 degrees through the wall to a pan in an adjacent en-suite shower room.
The client wants to put a close coupled wc in the bathroom on the same wall that the soil runs along and connect it into the existing soil pipe.
If I put a branch and straight pan connector in this will throw the cistern off the wall.
Does anybody make a soil branch where the centre connection is a pan connector rather than a 110mm socket?
Or any other bright ideas short of creating a box behind the cistern.
Cheers
Paul
I would find a pan that has the outlet further off the wall.
We did some pans recently, that were P/Trap pans that could be turned into S/Trap pans with a gooseneck adaptor,
From memory, when using pans as P/Trap the distance off the wall to the pan outlet was either 250mm of 270mm.
Might save you some trouble and finding a close coupled pan that suits the installation
oz Thanks. I'll get the client to ask his supplier if they can supply something with the outlet further away. Don't suppose you remember the manufacturers do you?
Chester At the moment the soil is behind a bath, but will be exposed when the bath is moved to the other side of the room. It will have to be boxed in and tiled on completion.
if its cheap some of them don't leave a lot of room behind the pan, I've had trouble getting space saving connectors on, so with a tee there's probably no chance. maybe a back to wall type would be easier/more space, and still look nice, just a thought.
Reply to WC branch pan connector in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had a plumber in to replace my old pan connector as it was leaking due to the wax deteriorating. Now when this toilet clogs up (which is a separate issue), it leaks from somewhere at the back. I can't tell where it's from but can tell for sure it's not from the water inlet or the toilet side...
Hi guys, I’ve got a close coupled toilet wher the waste come out of the back of the toilet then it’s a 90 degree bend to the right where it goes off through the wall. However with the 90 degree pan connector pushed into my soil pipe, the pan connector end isn’t long enough to reach the back of...
Hey Guys I’ve noticed this weekend that my en-suite toilet pan water level is seeming to regress after an hour. Toilet flushes as normal and water levels are all fine in the cistern. If I flush the toilet and wait all looks fine. However after an hour the water levels have dropped by a couple...
Hi, fitting a back to wall toilet in a small cloakroom. The soil pipe is a vertical clay pipe about 20cm from the wall and so I will have to build boxing to be able to fit the toilet to the wall (this will hold the concealed cistern). I bought a flexi 90deg pan connector for back-to-wall...
1K
Deleted member 120897
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the branch) and plan to place it the opposite end of the room. I was pretty lucky to find a 110mm sewer waste pipe below the old sink which is the new...
