Discuss (Well known?) Issue with Remeha Avanta boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Remeha Avanta boiler, which works fine, but two different gas engineers, one from Baxi and one from British Gas Services have identified that there is known problem with these boilers, in that the downpipe at the rear of the boiler (a condensate trap?) is known to become rusty, and can lead to boiler failure. I was told that a repair kit ( a rubber elbow joint?) is available from Baxi, who now own Remeha. I contacted Baxi's technical helpdesk, who said
"We aren't aware of a 'repair kit' for this model. If this is something the British gas engineer has mentioned you'd need to follow it up with them as it may be something that only British gas can supply."
Can anyone assist, and/or point me towards a more technical description of the problem, or the repair kit, so that I can get a useful response from Baxi?
Just to be clear, I do not intend to attempt any repair, I will use a registered gas engineer, but what spare part do I need?
Why not let your engineer or bg get it?
Fair point, but if the Baxi Technical Help Desk are (in their words) 'not aware of a repair kit', then I don't want to pay someone to look for something that might not exist. As such, I'd like to be sure that this 'repair kit' is a real thing, and available somewhere, before trying to get hold of it, so that it can be fitted.
It's not a repair kit, it's just a rubber connection that fits onto the bottom of the condensate trap and connects to the condensate waste pipe. Most installers just connected the trap to the waste pipe and over time that rusted the case around the connection which meant the boiler was a write off. Maybe baxi help didn't recognise what you meant because you referred to it as a repair kit?
Thanks, pip. Much appreciated.
Reply to (Well known?) Issue with Remeha Avanta boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
Hi I've been to a customer today that has a 9 year old baxi duo tec40kw boiler,it runs 20 radiator that all work fine,they have 2 bathrooms and 1 electric shower and again have no issues with hot water.Over the last 4 years baxi have repaired the boiler on 8 occasions, with faults on gas valve...
Hiya - posting in this forum as I'm guessing this relates to my neighbour above's boiler, but I may be wrong so please say if so. Basically the attached pix and vids show my issue. I've got a small copper-looking pipe protruding from the wall above my rear tenement bedroom. It's dripping almost...
I have a Worcester Greenstar gas boiler circa 2017. There has been a noise coming from the boiler which resembles running water, I have checked the system pressure at 1.5bar and the relief valve but the noise persists unless a hot water tap in the house is opened then it stops for a period of...
Hi, Looking to see if anyone can give some advice please. My Baxi boiler has been losing pressure and I am having to top it up approx. every 4 hours from 0-1.5 bar each time. This has been going on a week now. I have also started to notice small drips running down my condensate pipe...
