Discuss wet and dry vac in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbdoctor
i brought a eckhon one cos it was suppose to be the dogs nuts but its pants if your only sucking up little bits of water i throws it out the blower any plumbers out there recommend a godd wet/dry vac
Agree with above, fantastic bit of kit. I only wish it'd hold more water.
I have a george and he is ace, but his tummy is quite small and he fills up quick!!!! Oh yeah he then wets himself and the custards carpet.... :(
i got one from wicks,less than £40,best tool i have,great for draining rads,also blows,
i've got a george - but i don't think he blows. (if ever there was something i said that I hope doesn't get taken out of context...)
i've one similar to that stan but it's made by einhell like this BT-VC1500SA-Image_1.jpg it's very powerfull and has a power takeoff
Erbaurer is exactly the same as that Steve. Did you compare to Screwfix before you bought?
Ones what blow , also make good sprayers ,
( clue normally revs begin to drop when fan gets wet )
Ive got an Erbauer one, when sucking water it sprays it out of the machine vents! Up the walls & over the carpets, i wont be buying it again!
Got the Wickes one. Its ok. I had the same one as stan, but tipped it over while it was full of water, and switched on. That killed it quick.
The wickes one is ok, but it's a pain if you need to hoover up dry dust and rubble. The bags are quite expensive and don't last long....if you don't use one, it will litterly blow it back out the hoover!!
I've got two Wickes one at the moment. One of them was full, I left it outside a clients for 3 hours, and it froze solid (in that very cold snap we had a few months back). I had another job to go to, so just bought another one on the way!! Well they're only £40.
When the other one thawed out, it was fine. So it's in the shed.
i have had a wickes one for few weeks and promptly lost all the bags cant say have had any issue at all with it blowing out
Maybe I'm using the frozen one and its knackered! Its OK on water which is the main reason I'll use a hoover.
If it's dusty work I tend to sheet up, and the two blokes that work for me carry Henry's, so I'll use them. Can't beat a Henry for dust!
Wet-/Dry Vacuum Cleaner Ultra 30 ShopVac 9240429 in the Conrad online shop | 816023
Best wet vac I've ever used by far! Had it about 6 months now and not once had even a minor problem with it.
Used numerous different cheaper models from fellow engineers, but was always let down by either the suction not being poweful enough, or them spraying the water out just as quick as they suck it in.
Also doubles up as a dust extractor as it has a handy little switch on it, that when engaged only fires up the vac when you start using the power tool
Although I only ever use it for wet work, which is great seeing as it has a drain point on it so you dont have to take it apart to empty it
One of these day's i am probably going to invest in one! I would like to see a video of one in action first!
Looks quality. Is is 240V? Looks american.
Yeah it is German, which means it does come with a 2 pin plug on it.. (240v though)
Nothing a pair of wire cutters and a 3 pin plug couldn't solve :innocent:
I've just picked up a wickes one. Just using it for wet pick up though, I'll stick with Henry for dry pick up.
So you carry two hoovers? I wish I had room to do the same. I genuinely do. Gonna get a bigger van this year.
Should be 230V? as that is the European harmonised mains voltage specification.
Oh yeah.. sorry I ment 230v :yes:
Just a little hint though, try not to fill it all the way up when upstairs (as getting 30 litres of dirty water down the stairs is always a bit of a worry)
Stairs are no problem, it's mre fun getting it down out of a loft. after having cleaned out a header tank
If you dont mind cleaning the sink and surrounding area afterwoods :p
And yes that is very true, only had that dilema a couple of times so far, but that really is when you pray the plastic catches holding all that water in the base to the handle on top dont give in!
Yeah, now that is fun! Load of brown water swimming around in the hoover. Not a nice job to attempt on your own. Pottential to go very badly wrong. Doesn't bear thinking about really.
Hold it from the bottom. Relying on the plastic catches (not that mine has any) is just asking for trouble!!
Just hope for the best and get it over with as quick as possible.
Holding it from the bottom is my preffered method, but when your trying to get in through a small loft hatch at the same time that you are climbing through it gets rather tight :tounge_smile:
I leave it in the loft, climb out and then take the wet n dry out holding it round the bottom. No danger of me having to do this through a small loft hatch as I don't fit.
Reply to wet and dry vac in the Plumbing Jobs | The Job-board area at PlumbersForums.net
