Currently reading:
Wetroom screen leaking
Discuss Wetroom screen leaking in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
So I have a question here and I’m completely lost, I had a shower screen replaced as it shattered. The fitter came and fit the new wall profile to the wall then fitted the glass and then sealed it with silicone. When I first used it it started leaking from the bottom corner as shown in the pictures. He came back and Re fitted class with new silicone and I allowed it 4 days to set. The same issue has happened again where is it leaking on the outside in the corner by the profile. Any thoughts on why this happens from the images? Much appreciated and help
Normally seal on the outside only and up the glass where it meets the profile abit
Tbh all of it from the inside needs removing as it could trap water if it gets behind
am i correct in saying the outside should be sealed as per the attached image. As in along the wall profile between the profile and the tile down to the corner then across the bottom from the corner along the profile to the end of the glass? along with silicon inside the prifle where the class touched the wall part of the profile only? and then to not put any silicone on the inside of the shower, just seems like not enough silicone if its one bead between the glass and then wall part of the profile.
Correct where the red line is on the outside
and at the bottom where the glass meets the chrome profile around 2” up from the bottom
none on the inside
Hi Shaun
thanks, so where I have marked the red with the arrow on the outside that should be siliconed? It’s leaking where it’s circles green ......
Then with the inside image, the blue silicone should stay? But the purple should be removed?
thanks for you comments
Yes your first image with the red lines is correct and your second image with the red line (green circle) also wants doing on the outside
inside wants completely removing of silicon
As Shaun says, silicone all your red lines no silicone for blue or purple.
The glass/profile on the outside I do 100mm, but I suspect 50mm is sufficient.
The reason yours is leaking at the green point is that water is getting inside the profile - this is designed to happen by the way- but because you have sealed inside the cubicle the water can’t run out onto the tray as it’s supposed to do it comes outside at the glass/profile joint in your green patch.
Sealing this area up 100 mm will stop it coming out this way, but removing the inside silicone is the most important step -as this allows the water to go back onto the tray and down the drain.
hi Ben
thanks, so the silicon on the outside should cover the gap between the glass and the silver profile where I put the red arrow pointing, is it ok to do this without removing the glass? As in just run the silicon up 50 mm. the guy was trying to say run it all the way up to the top of the glass for his third attempt to correct the job
And for the inside, yeh seems bizzare that the water will run freely out by removing the silicone along the purple line. So it’s ok that water gets into the profile but just needs to be able to escape at the bottom?
Thanks again
Does the glass come out of the profile normally there bonded in /sealed in
Bottom 50/100mm is all that’s needed - provided glass has been fitted into profile properly...
Looks like yours is the type where you screw the profile to the wall and then run a bead of silicone inside it and just push the glass in - that needs doing with enough ( but not too much) silicone and in a continuous bead with no gaps.
This requires a higher skill level than the screw together type or the profiles with integral rubber seals, but it’s within the capability of most!
Also with all profiles the little 25mm section between tray and tiles that is behind the profile is critical - this gets left out far more often than I can believe by shoddy workmen. This usually shows as a leak on ceiling below or wall backing on to shower.
And don’t worry, yes a single bead of continuous silicone on the outside is all that’s needed - last time - definitely no silicone inside.
I always seal the inside - shock horror! I don't think there would be any other scenario where you wouldnt seal the side that the water is coming from. I've never had one leak either.
Looking at the quality of the silicone work Id say that 'could' be the issue
Reply to Wetroom screen leaking in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
