Discuss What do I need to cap these pipes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
Please forgive my ignorance but I was hoping someone could let me know what I need to cap these two pipes so I can disconnect my tap and toilet from the water supply... the toilet one has a screw on it - is that for isolating the connection?
Many thanks!
Ross
1/2 brass cap and washer
Blank Nut ½ x
And a 1/2 tap washer
Arctic Products Pegler Tap Washers ½
Don't forget to turn the water off first
Yes the toilet has its own isolation valve
Suggest you put the same on your basin tap pipes
Turn the screwed one to quarter to three . In otherwords horizontal . The other pic needs a 15mm cap but with a fibre washer in .
Personally I would isolate the water and use a 15mm insert and pushfit cap after the isolation valve on the toilet and remove the coupler from the bottom union on the tap connection and use a 15mm compression cap
And make sure the insert is inside the pipe for the tap
Reply to What do I need to cap these pipes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
