Discuss what do you guys make of this in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ambrosia
Is that rubber on the top of the flue ?
the above pic is ducting and at the bottom a fan providing the mechanical ventilation to a plant room, going through the ducting is a gas pipe.
even with the obstruction its providing ample air. the gas pipe is not sleeved and i cannot be certain if its a straight piece of pipe with no joints
going to hold off saying how i classified it as im interested to hear your opinions
I wouldn't like it either
I would hole saw into the side of that box and look to see what's inside. Then I would make a decision. Obviously cover the hole again after I've seen what's inside.
There are many options. One would be to sleeve it all the way through the box but you won't know what's possible until you've had eyes on it.
in the end i put it down as an AR, because it has no sleeve i was able to. However as wrong as it seems if it was sleeved i couldnt think of any reason to AR it.
it was in a hospital/old peoples home, so IDing it was to be avoided for as long as possible, but there was also no high ventilation or extraction (although not effecting combustion), they were using the plant room for storage and half the plant room was full of combustable looking rails of clothes. no earth bonding with electrical flex attached to every bit of gas pipe i could see
rough choices, who'd have thought box ticking would be so hard, life aint easy for a gas man
Looks like it could be ab?
That changes things!
I cannot see the pic properly because it's a bit blurred.
Does it look like asbestos to you Ambrosia?
Story of my life lol
Sorry, just re read the post above and you mentioned it yourself.
I skim read it before.
Reply to what do you guys make of this in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
