Discuss What has she got bit confused. in the Plumbing Forum area at UKPlumbersForums.co.uk.
Tags:
  1. Bogart
    Bogart Member
    A daughter has move into a property with the following setup. All electric setup with mains pressure HW cylinder. Pic 1 shows normal 3bar relief valve. Pic 2 shows a 3.5 bar valve on the mains incoming and a 6 bar valve going to the expansion vessel. Pic 3 shows the stopcock which has me a bit bemused as to why the incoming water has a stopcock on it, as one would expect,but then a parallel set of pipes directly below?
  2. ShaunCorbs
    I would say cold mains and hot
  3. Bogart
    Bogart Member
    Will run it up and see. Am assuming the 3.5 bar and 6 bar items are a combination valve.
  4. ShaunCorbs
    Correct why do you ask ?
  5. Bogart
    Bogart Member
    Just checking as never seen one before.
Loading...
Similar Threads - confused Forum Date
Confused - kitchen mixer with shower plumbing requirements. Plumbing Forum Mar 21, 2018
Really confused on flue position Gas Safe Register Forum - Public Forum Feb 20, 2018
