M
mrlennie
The flex rubber strips that adhere to bath or shower tray, make a good upstand.
Please post link of such items!
Discuss What is the best bath sealant? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dow Corning goes black within a year or so, where used in places that are damp, like showers. Forever white is easier to use & garanteed to stay white 10yrs. Tec 7 is hard to use as a sealant, but grips clean surfaces well. The flex rubber strips that adhere to bath or shower tray, make a good upstand.
One make of bath/shower seal is " Classic Seal ". It is a thin rubbery strip about 50 mm wide & you can get it in various lengths. Half of the width of it has a thick black adhesive & it comes with a paper you peel off as you stick it to tray/bath. It bonds immediately, so got to be right, but easy enough fit. It allows about 15mm movement I think. You end up with a 25mm thin up stand which can be tiled over. Really simple solution!Please post link of such items!
I thought same, but found it going black where a lot dampness. Even a little black dot or two ruins look of jobs. Dow is harder to work with also.Dow goes black? then we are all done for! There's me thinking it was Rolls Royce stuff. :angry_smile:
I'm just bumping this thread for no particular reason. If it isn't a current topic, don't worry about it, just ignore it and it'll move off the forum list before long. If it is a topic you'd like to reply to though, go ahead.
There wasn't a clear winner, but the Dow Corning seemed to be the benchmark.Not sure this thread states it's the best does it?
Reply to What is the best bath sealant? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
