Discuss What kw do i sensibly need? in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. davrave
    davrave New Member
    I have a 2 bed mid terrace
    it has 6 rooms
    1 bathroom
    1 small shower room / utility room
    2 beds
    lounge
    kitchen
    I have 6 radiators plus 1 towel radiator
    My house gets warm very easily
  2. ShaunCorbs
    Copper cylinder??
  3. davrave
    davrave New Member
    the pipes are copper coming from radiators if that helps though some are the flexible pipes
  4. ShaunCorbs
    Hot water cylinder??
  5. davrave
    davrave New Member
    it comes from my combi boiler
  6. ShaunCorbs
    Combi boilers are rated on there hot water demand not the heating kw / capacity
    28-32kw depending on your cold mains flow
  7. davrave
    davrave New Member
    ok thank you
  8. scott_d
    scott_d Plumber GSR
    What have you got at the moment?
  9. davrave
    davrave New Member
    A Heatline, it was in when i bought the house
  10. davrave
    davrave New Member
    heat line compact
  11. scott_d
    scott_d Plumber GSR
  12. davrave
    davrave New Member
    it does not say on unit, however it is all analogue
  13. Vinod
    Vinod New Member
    Higher the kw the more hot water flow you will get
  14. scott_d
    scott_d Plumber GSR
    Any pictures?
    Have you had any quotes or just doing some research?
  15. davrave
    davrave New Member
    wanting to replace it but do not went to spend fortunes
Loading...
Similar Threads - sensibly need Forum Date
Loss of cold water supply to bathroom - conflicting views on how to resolve the problem! Need advice Plumbing Forum Yesterday at 9:50 PM
Newly qualified engineer, Need to be taken on as trainee Looking for a Heating Engineer? Post Jobs Here Sep 11, 2018
