Discuss What sealant do you recommend? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi.
I work in a care home and the sprinkler system tank is leaking from a weld in the tank. What sealant do you recommend using on a permanently wet surface, with the tank still filled with water?
Thank you in advance.
Isnt it a safety concern if its leaking?
There are some tapes,sprays and and sealants that claim to work in the wet. They look amazing in the videos but never tried one
Has the company that maintains the sprinkler system to the required standards, certified it as O.K with a leaking tank?
A temporary supply could be brought in whilst the tank is repaired properly, although if it's got 1 leak on a weld it may have more and be scrap.
You could use emergency roof repair/seal, works in the wet and on most materials and usually fairly long lasting. Clean off the mushrooms first though...
Evercryl Roof Repair 310ml Grey - Toolstation
http://www.NoLinkingToThis/p/thompsons-thompson-s-emergency-roof-seal-black-1ltr/87810
Hi.
MS Pool würth ... it's an amazing product sticks even under the water.
It is auto filling so the water is never low. So it still serves its purpose.
it can be emptied, just need to follow the protocol
and fyi if the water board come round they will shut you down for wastage of water
Reply to What sealant do you recommend? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
