Discuss what shower unit for megaflow boiling system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I have a megaflow in my house and I want to install extra shower in my bathroom, what kind of shower will this megaflow support? Thermostatic mixer showers or mixed shower?
thank you in advance!
Henry
If you mean thermostatic or non thermostatic showers, then either type will work but a thermostatic shower valve is much advised as the hot water is usually over 60 degrees & not blended normally at Megaflow (can be done if wanted). Especially for children or elderly you need themostatic valves anyhow, & high pressure/flow makes it more risk of severe scalding.
Agree with Best tho I have had a Megaflo system on the past and had both thermostatic and non thermostatic showers in the same property.
Question is, will anyone stupid enough to scald themselves be allowed into the shower unsupervised??
the first thing you need to check is that the megaflo will cope with the shower you choose... meaning, check the litres per min on the spec of the shower to make sure you have a big enough megaflo to cope with the water usage. e.g, if you are looking at a drench head shower that can take (talking extreme) 30 litres per min, and your megaflo is only 120litres, you will only get 4- 10 minutes of hot water, depending on how hot you have the water.
once you know this, you can decide on the shower, thermostatic or non.
Hi
thank you for all input!
the megaflo I have in my house is same as this one
Heatrae Sadia Megaflo HE Unvented Indirect Water Heater CL170HE
the shower I am interested is one of them:
(a) Mira Element Thermostatic Shower EV (Exposed Valve) All Chrome
or
(b)Aqualisa Midas 300 Exposed Shower Combi/High Pressure MD300BAR
Does any of above shower work with my megaflo? and why?
appreciate for your help!
best regards!
Reply to what shower unit for megaflow boiling system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
