Discuss What size Square shower head is best? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Hienekinuk
    Hienekinuk New Member
    I intend installing an Aqualisa digital shower in my loft. . My water pressure is 5 bar. Flow 14l./min. with a combi boiler. As I fancy a square shower head from the ceiling, and would like as much flow of water as I can get . Should I then install the largest square head I can ? Or would a medium one be better as regards flow and pressure. So what size and type is recommended ?
    Thank you for any advice and suggestions
    Heinekinuk.
  2. king of pipes
    If your want something a bit different look on mano mano uk.co.uk 200mmx200mm is the normal size. Cheers kop
Loading...
Similar Threads - size Square shower Forum Date
Boiler size and costs Commercial Plumbing Forum Thursday at 7:17 AM
Standard size for the cut out on a kitchen sink Plumbing Forum Feb 11, 2018
