Discuss What transition layer between tiles and chipboard with wet ufh. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
Hello peeps,
I'm currently in the middle of a full house refurb and the customer is having wet ufh retro fitted between joists on a 75mm layer of kingspan and dry screeded to top of joists, then a 22mm chip board flooring on top. What would you guys recommend as a transition layer.... plywood, warmafloor insulation etc. I'm swayed to 6mm warmafloor insulation board, would this have a massive effect on heat coming through, maybe just take longer to filter through.
cheers
Why would you want to insulate on top of the floor? That would render the ufh useless.
Are you wanting to tile on top? If so it would have been better to ditch the chipboard ( another insulator). A better one would have been 25mm fermacell element flooring as it is a cement/ gypsum product, it is stable and you can tile direct.
A cheaper method is to again remove the ply and fit 12mm cement backer boards, and tile to that.
If your not tiling, you can carpet straight onto the chipboard. I just hope they have solid filled the biscuit mix, right to the underside of the board. Or it will struggle to heat the room.
Hi guys,
I'll totally agree with Chalked.
insulation is designed to stop the heat to pass through so I would never recommend to use it on top of underfloor heating.
Is there any reason why there's 22mm chipboard required? Normally people go for 18mm which is load-bearing.
If you are tiling on top they you will be ok with UFH as tiles have got hardly any thermal resistance, you will easily get approx 70W/m2.
If you use any other floor finish you need to be careful and check the thermal resistance of each layer that goes on top.
For optimum performance we advice that the maximum combined thermal resistance, for floor coverings, of 0.2m2 K/W is not exceeded which is equates to 2 TOG.
Hope that helps.
The original question is for recommendations for a transition layer, used before tiling. i'm not trying to insulate above the underfloor heating, it's just been suggested to use warmafloor to separate any thermal movement to prevent cracking/ tile lift. And I have retrofitted ufh before a a couple of times thats worked with aplomb even with underlay and thick carpet.
Reply to What transition layer between tiles and chipboard with wet ufh. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Evening all, I’m currently in the process of refurbing my house, and have opted to wet UFH for the whole of the downstairs. The upstairs will be radiators. The flooring I’ve chosen is 14mm thick engineered wood and I just wanted to know the best way to do things. At current, the builder was...
Done a fair bit of reading and spoke to numerous plumbers/heating engineers and I get so many different answers to my question. By nature I'm a pretty inquisitive bloke and like to know how things work and if its the best way to do things. So my first question is does a single zone UFH setup...
1K
I'm in the middle of refurbing my bathroom, I have removed all the plasterboard, back to the stud work and also lifted up all the chipboard flooring (22mm), this is a small ensuite bathroom (3mx2m). My plan is to fit new flooring, 18mm WBP and then 6mm Hardie backer board to the floor, planning...
1K
Hi, as part of an extension/refurb project I will be fitting UFH over a new concrete floor as well as existing joisted timber floor. Both floors being within the same room. My question is whether anyone has done this mix of subfloors before and noticed a performance/temperature difference...
3K
Hi folks, my first posting and hopefully it's a sensible question. I'm doing a renovation and intend to heat with wet UFH supplied from an ASHP. I have to go for minimal build up because of head-room, so I'm looking at the various low profile systems. Insulation of the property will be OK...
4K
Deleted member 110239
