Discuss whats the best additive for circulation problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gary80gas
Ive got a heating system boiler where even with the pump running continuously it occassionally takes opening the hot water circuit to get the heating hot. This somehow overcomes resistance to flow.
Theres some air(gas) I can hear circulating that wont vent anywhere.
What would be the best additive to clear air(gas) and also aid the circulation?
Im looking for low budget solution. Thanks.
Reply to whats the best additive for circulation problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an older gas boiler HW heating system with a taco circulator pump for each zone that worked fine last season. When turning it on for the 1st time this season I found a problem with the boiler not running on one of the zones. If I turn on the heat to zone 1 I hear the system...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up blowing/melting a hole in one of the pipes. I repaired this by putting in a new stretch of pipe in and just connecting it to the existing pipes with two...
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but I'd like to do it myself if possible. All images for system here: https://*********/a/ngPQkre Last winter the temperature switch on my boiler...
Butchy10
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented tank, zone vavles, pump, expansion is on first floor in airing cupboard - Currently piped as S-plan. - Hive controls. - Would like to fit 6-zone...
Hi everyone, I'm a (somewhat, I hope...) competent DIYer and just want to get some advice if my suspicion on a problem we're having is correct. We had a Megaflo and boiler professionally installed as part of a renovation a couple of years ago. I will add all of the pipework was done by this...
